Multisim and Ultiboard
Hey bro! I have a big problem using 7447 (binary decoder)Must I put resistor to those input ?Please help :'(
(4,492 Views)
You have made 2 errors.
1. The CA pin of the indicator should be connected to net VCC.
2. Pins LT, RBI, BI/RBO of U1 should be connected to net VCC.
(4,482 Views)
Dear Sir or Madam
I,Ardit Halimi, kindly request from you to help me fix a problem with circuit, as im very first beginning it was functioning very good, and now there has appeared a problem.
It is not operating properly.
I really do appreciate your help.
Sincerly yours
Ardit Halimi
(4,319 Views)
You should use U2 = 7 SEGMENT DISPLAY, COMMON CATHODE (SEVEN_SEG_COM_K_GREEN)
(4,312 Views)
Please, correct my mistake.
(4,245 Views)
(4,235 Views)
