04-05-2008 07:54 PM
04-06-2008 08:16 AM
I have tried this before by taking a model and creating a component with some success. The model works and puts out the desired voltage, but I keep getting a pop-up error messsage about "Too few parameters in subciruit". The simulation continues even with this error poping up.
I am going to post a schematic with this power source on it. Save it to your user database (if it will allow it) and maybe you can take it further and adapt this to your application. Once you get this one source you can create other sources by just changing the model data to reflect the new voltage value.
Multisim won't allow modification of the master database power sources (other than changing the values in the dialog box) as they are considered interactive components. This means no copying or saving is possible.
Here are the two files. Note: The zip file I am going to upload contains a bunch of other models that you and other user may find useful. I was going to just post the one text file, but I think that this whole zip file may be useful in helping others in finding models.
04-06-2008 11:02 AM
04-06-2008 05:58 PM
Good luck with that one. I am not sure that is going to be possible. Let us know if you actually are able to do this as I have not had any success with attempting something of this nature. Most of the time I have to simulate a design as one unit and then break it apart into 2 separte schermatic files and export them individually in order to get two separate boards.
This is situation presentented itself one other time and gave me an idea I have already sent to NI. My idea was to have the Multipage in Multisim have the ability to export each individual page that way you could have one schematic and be able to simulate it as one unit and then transfer each indiviual page as a separate board.
I hope you can find a way to get this accomplished as I have no Idea on how to do other than what I have stated.
05-07-2008 01:36 PM
