Multisim and Ultiboard
Custom character lcd 16x2
There's a problem with building custom characters in Multisim 11.0.. I used 16x2 lcd, but on using the following code it shows only the first character. Tried everything, but no progress... Can someone pls tell me a fix to it..
//Program to create and display custom characters  smilies, heart, musical note symbol
#include<reg51.h>
sfr lcd_data_pin=0xA0;
sbit rs=P3^0;  //Register select pin
sbit rw=P3^1;  // Read write pin
sbit en=P3^6;  //Enable pin
void delay(unsigned int count)  // Function to provide time delay in msec.
int i,j;
for(i=0;i<count;i++)
  for(j=0;j<1275;j++);
void lcd_command(unsigned char comm)  //Function to send commands to LCD.
lcd_data_pin=comm;
en=1;
rs=0;
rw=0;
delay(1);
en=0;
void lcd_data(unsigned char disp)  //Function to send data to LCD
lcd_data_pin=disp;
en=1;
rs=1;
rw=0;
delay(1);
en=0;
void lcd_ini()  //Function to initialize the LCD
lcd_command(0x38);
delay(2);
lcd_command(0x0F);
delay(2);
lcd_command(0x82);  //Set cursor to blink at line 1 positon 2
delay(2);
void character()
lcd_command(64);  //Address where values of the first custom character is stored
lcd_data(0);
lcd_data(10);
lcd_data(21);
lcd_data(17);
lcd_data(10);
lcd_data(4);
lcd_data(0);
lcd_data(0);
lcd_command(0xC0);  //Address of the location where the character is to be displayed
lcd_data(0);  // Displaying the character created at address 0x64
delay(10);
lcd_command(72);
lcd_data(0);
lcd_data(0);
lcd_data(0);
lcd_data(10);
lcd_data(0);
lcd_data(4);
lcd_data(17);
lcd_data(14);
lcd_command(0x80);
lcd_data(1);
delay(10);
lcd_command(80);
lcd_data(0);
lcd_data(0);
lcd_data(10);
lcd_data(0);
lcd_data(4);
lcd_data(0);
lcd_data(14);
lcd_data(17);
lcd_command(0x82);
lcd_data(2);
delay(10);
lcd_command(88);
lcd_data(1);
lcd_data(3);
lcd_data(5);
lcd_data(9);
lcd_data(9);
lcd_data(11);
lcd_data(27);
lcd_data(24);
lcd_command(0x84);
lcd_data(3);
delay(10);
lcd_command(96);
lcd_data(0);
lcd_data(10);
lcd_data(0);
lcd_data(31);
lcd_data(17);
lcd_data(14);
lcd_data(0);
lcd_data(0);
lcd_command(0x86);
lcd_data(4);
delay(10);
lcd_command(104);
lcd_data(10);
lcd_data(0);
lcd_data(4);
lcd_data(0);
lcd_data(14);
lcd_data(17);
lcd_data(17);
lcd_data(14);
lcd_command(0xC2);
lcd_data(5);
delay(10);
lcd_command(112);
lcd_data(0);
lcd_data(10);
lcd_data(0);
lcd_data(0);
lcd_data(4);
lcd_data(0);
lcd_data(31);
lcd_data(0);
lcd_command(0xC4);
lcd_data(6);
delay(10);
lcd_command(120);
lcd_data(0);
lcd_data(17);
lcd_data(10);
lcd_data(17);
lcd_data(4);
lcd_data(0);
lcd_data(14);
lcd_data(17);
lcd_command(0xC6);
lcd_data(7);
delay(10);
void main()
lcd_ini();
character();
(4,611 Views)
Pls ignore the syntax.. I've actually changed the syntax as required by the Multisim, but pasted here the code from original source website..
Also I used #include <htc.h> in place of first line as shown in image..
(4,610 Views)
