If needed for simulation then I have not been able to locate a model for this component. If there is no model availble then you won't be able to simulate it.
If you need it just for the board layout then you need to create a blank component with no model. Use the component wizard and the datasheet to create the symbol and assign a footprint for it.
This is about I know on this and I hope it is of some help.
