Multisim and Ultiboard
Diagram charge battery
Hi, does anyone have a diagram that shows how to charge a battery. I want to simulate this
Input voltage: 4.4V 500mAh
internal consume: 40mAh
Battery capacity; 1800mAh (3.7V)
What I want to simulate is the necessary time to charge the battery. If the diagram has a solar panel. It could be great.
Thanks anyway if you have something and want to share it with me.
(5,066 Views)
Hi Singleroot. I have some interesting links for you:
To charge a battery using a Solar Panel you can connect them using a diode:
http://electronics-diy.com/electronic_schematic.php?id=679
Other more sofisticated circuits are these:
http://electroschematics.com/4746/solar-charger-circuit/
http://electronics-diy.com/electronic_schematic.php?id=681
However, If you plan to test other battery charger, please check these:
http://www.eleccircuit.com/usb-powered-lithium-ion-battery-charger-by-lm3622/
http://www.eleccircuit.com/li-ion-battery-charger-for-mobile-phone-by-tl431/
http://circuit-zone.com/index.php?cat=battery_chargers
(5,021 Views)
