Multisim and Ultiboard
Dual gates in Multisim
Are there dual gates in Multisim. For example can I swap a negative AND for an OR gate? Are there any negative gates in Multisim? Negative AND, negative XOR...
(5,189 Views)
Hi Curtis123,
You'll find them in the Master Database -> Misc Digital
PedroR
(5,135 Views)
Hi Pedro,
Thanks for your help but I still can not find a negative gate even in the Misc Digital area of the Master database. These are not NOR or NAND as they have inversion on the output. I am looking for negative devices that have inversion on the input. For example swapping an OR gate for its De Morgan equivalent Negative AND.
Image result for de morgan devices
(5,131 Views)
Accepted by Curtis123
Curtis123,
I understand, in that case, you'll need either to use a NOT before or create your own component following the tutorial below:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YH5fCAG&l=en-US
PedroR
(5,127 Views)
Thanks again Pedro.
I have created the gates that I require.
Cheers,
(5,121 Views)
Would you be able to share the Dual Gates you created?  Is there a way to export and import them?  I wanted to be able to place gates with demorgan equivalents to teach bubble-matched schematic drawing techniques.  I'd love to use a library of these gates if someone has already gone to the trouble of creating them.
(4,102 Views)
