Multisim and Ultiboard
Duplicate the layout for multiple instances
I have a small PWB to manufature (.5 x .5) . Instead of having many of the small ones fabricated I want to fabricate a sheet of them and then seperate them. Any suggestions how to do this in Ultiboard?
(3,511 Views)
Accepted by EE_Yeti
You can't, Ultiboard does not support palletizing.  If you try to block copy the board within the workspace, it auto updates all the refdes values.......which means you'd have to manually edit each part to reflect the right value.......screw that.......what you need is Gerbtool.  Find a copy of that and it will generate the copies you need and create palettes of your board nicely.
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(3,508 Views)
