Multisim and Ultiboard
Equivalent Transistors
I am trying to find equivalent transistors for the following part numbers to use in Multisim 9:
2N2219  and  2N3553 or 2N3924 or BFS22A
Thank you,
Alan
(10,644 Views)
I am not sure I quite understand what you are looking for. Are you wanting a model of the NTE/ECG replacement components for these transistors? If the latter is the case, then the models contained in the database (at least in my database) should be the same as any replacements or so close it shouldn't really make too much of a difference.
Let me know if I misunderstood your question/request and we will proceed from there.
Edit: I see now that there are some that are not there. I do have the model to the 2219 transistor for you that I will post. This comes from Multisim 2001 Parts Database so it should work. I do not have the others though.
.MODEL 2N2219 npn
+IS=1.88099e-15 BF=172.023 NF=0.893712 VAF=13.1259
+IKF=0.522911 ISE=3.04631e-09 NE=4 BR=0.1
+NR=1.0076 VAR=1.57026 IKR=5.22911 ISC=1.83175e-12
+NC=3.92593 RB=8.81602 IRB=0.1 RBM=0.1
+RE=0.109833 RC=0.549165 XTB=1.75031 XTI=1
+EG=1.05 CJE=1.67272e-11 VJE=0.83191 MJE=0.23
+TF=3.573e-10 XTF=0.941617 VTF=9.22508 ITF=0.0107017
+CJC=9.98785e-12 VJC=0.760687 MJC=0.345235 XCJC=0.9
+FC=0.49264 CJS=0 VJS=0.75 MJS=0.5
+TR=3.55487e-06 PTF=0 KF=0 AF=1
Message Edited by lacy on 03-26-2007 01:35 PM
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(10,642 Views)
