Multisim and Ultiboard
Where is the autoplacer function / menu in Ultiboard 9 ????
Hello, I am using Multisim and Ultiboard 9 and I am looking fo the AUTOPLACER function where the program wil automatically place the components on the circuit board for you...however I can't find this menu/function anywhere? I am using the Power Pro version. Also, is there a way to put the Auto route functions in the main menu at the top of the window? Right now all I have is two little 'Icons" in toolbar form, one to start the internal router and one to stop it...but again, no autoplacer. Thanks
Brian
(4,790 Views)
In Ultiboard 9, there is a router that is installed with Ultiboard and the features on that version are limited.  If you purchased Ultiroute you should see the Auto place in the menu.
Tien P.
(4,768 Views)
I thought that Ultiroute was built into Ultiboard 9...are you saying there's another, separate program?
(4,764 Views)
In V9, the router that comes with Ultiboard is limited to 2 layers.  The Ultiroute version that is sold separately gives you more layers and if you purchased the power pro, it has the autoplacer in there.
In V10, if you installed the power pro version of Ultiboard, it will have the autolacer in there.
Tien P.
(4,755 Views)
Thanks for the clarification!
(4,746 Views)
