01-10-2008 02:58 AM
01-10-2008 09:03 AM
It seems like the switch SPDT_OPEN (X1) is the one causing the simulation error. That component is used for schematic capture only and therefore will not simulate. Try replacing it with the SPDT in the Basic Group, which can be found in the Switch Family.
If you're still having trouble, can you please attach the Multisim circuit file and I will try to look into it further for you.
01-10-2008 10:30 AM
08-30-2010 11:11 PM
I don't know what to do anymore, this error during netlist generation which I just can't understand. Please help me.
08-31-2010 04:36 AM
Hi Mell!
First of all you should create your own post, and not bury your question in an old post. There is a good posibility that it goes unread.
Second you should also attach a screenshot of the error that you report.
-Tom
08-31-2010 07:22 AM
Hey Tom,
I'm sorry for that, since I'm new here. By the way, I managed to fix the errors already. Now my circuit running great.
Thanks.
08-31-2010 07:27 AM
No problem ![]()
Good to hear that you worked it out!
-Tom
09-04-2010 12:14 PM
Hello again
I managed to make the circuit works as shown in the attachment previously, but I realized that the circuit is on without switching the SPST switch on. My project is controlling electrical appliances with the parallel port. So I replace the switch instead the parallel port.
I need help, I've thrown everything I got in my head to do this. When I pressed the simulate buttons, error windows popped out.
One thing I don't know how to post new message in here 🙂 sorry for that also Tom.
Thanks in advance
