Multisim and Ultiboard
Error during netlist generation
Hi!
So, I have a problem. I use Multisim 10 and I make circuit. The electrical rules checking everithing is OK.
But I try simulate, coming up the error messege:
I attached screen:
Please help me!
Thnks
Message 1 of 8
(8,413 Views)
Hi Domi820306,
It seems like the switch SPDT_OPEN (X1) is the one causing the simulation error. That component is used for schematic capture only and therefore will not simulate. Try replacing it with the SPDT in the Basic Group, which can be found in the Switch Family.
If you're still having trouble, can you please attach the Multisim circuit file and I will try to look into it further for you.
M.I.
EWB Group.
Message 2 of 8
(8,389 Views)
Not only that as mentioned above, but your phono jacks are layout only footprints and don't have modeling data......this would lead to your power supply of 9VDC not being grounded and its most likely looking for a point of reference for the battery.
Try to put a ground directly on the battery negative terminal and see if you can get a partial simulation.
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
Message 3 of 8
(8,383 Views)
I don't know what to do anymore, this error during netlist generation which I just can't understand. Please help me.
Message 4 of 8
(7,441 Views)
Hi Mell!
First of all you should create your own post, and not bury your question in an old post. There is a good posibility that it goes unread.
Second you should also attach a screenshot of the error that you report.
-Tom
Message 5 of 8
(7,428 Views)
Hey Tom,
I'm sorry for that, since I'm new here. By the way, I managed to fix the errors already. Now my circuit running great.
Thanks.
Message 6 of 8
(7,424 Views)
No problem Smiley Happy
Good to hear that you worked it out!
-Tom
Message 7 of 8
(7,422 Views)
Hello again
I managed to make the circuit works as shown in the attachment previously, but I realized that the circuit is on without switching the SPST switch on. My project is controlling electrical appliances with the parallel port. So I replace the switch instead the parallel port.
I need help, I've thrown everything I got in my head to do this. When I pressed the simulate buttons, error windows popped out.
One thing I don't know how to post new message in here 🙂 sorry for that also Tom.
Thanks in advance
Message 8 of 8
(7,376 Views)
