Multisim and Ultiboard
Error in Evaluation Trial
Hi, I downloaded NI multisim 10.0.1 for trial (evaluation version). However, when I open the program and choose evaluation option, it keeps saying "an unexpected licensing error has occured. Contact National Instruments Techinal Support at ni.com/support to resolve this issue". Could you please explain what it means and how I solve the problem? I have tried to install and uninstall it three times, but I kept getting the same message.
(5,249 Views)
In reply to this I will post what Nestor said in a previous post on the same subject:
This is generated when the license files are not properly installed or they have been deleted. You can try to repair the installation and/or re-install the software from the original CD, or if you downloaded the evaluation, make sure you have unzip the files in your local disk (C.
Individual license files should be installed when you repair, on any case, you can find the specific license to use depending on the Edition you have in here:
ftp://ftp.ni.com/support/circuitdesignsuite/licenses/10.0
And they should go in here:
C:\Program Files\National Instruments\Shared\License Manager\Licenses
Nestor
EWB Group
I hope this helps.
Have a Nice Day
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(5,242 Views)
HI! I have some problem with NI multisim 10.1 and some of other software. When i  try to download of file "Multisim_Edu_PKG_100000.lic" it saying that:
"SERVER THIS_HOST ANY 27000
VENDOR nilm
PACKAGE Multisim_Edu_PKG nilm 10.0000 COMPONENTS="Multisim_Core \
Multisim_Edu" SIGN=69DB9BD870E6
INCREMENT Multisim_Edu_PKG nilm 10.0000 1-jan-1900 uncounted \
VENDOR_STRING="TMP_DEMO EXPIRES=30" HOSTID=DEMO \
vendor_info="TYPE=Application \
URL=http://www.electronicsworkbench.com/products/ \
LABEL=Education Edition" TS_OK SIGN=2642510E4188"
How I can download this licence?
(4,690 Views)
