Multisim and Ultiboard
Multisim help Parallel in / Serial out 74LS166
i am  trying to connect the IC 74LS166 (Parallel in / Serial out) to my design, but i´m having trouble connecting this component, if anyone knows how this is done or any idea i would appreciate it.
i have the parallel intput from a 74LS374 which has 8 D-type flip-flops, basically i just need help connecting the control pins
thanks in advance;)
(5,805 Views)
I am having a problem with connecting it also...
It seems that the 74LS166 does not work at all.. I do not know how to get an output. The output always steady 0 V
tko_gx,did you have the answer yet?
(5,107 Views)
I find a answer in the web:
"If all the LS374 is doing is feeding the LS166 then you probably don't need it.
The 166 will latch 8 bits of data when you drive the load pin low.
The only other thing you need is a clock pulse to shift the data to the output port.
Of course you do need to wait until all the data is written out before doing another load. "
Regards
Nacer M. | Certified LabVIEW Architecte
(5,054 Views)
