Multisim and Ultiboard
Error in simulation: Not enough nodes found
Hello i am trying to simulate a simple active filter ckt using MAX9618. However, i keep getting error as Not enough nodes in my schematic I have attached the schematic for reference.
Can anyone please help me understand why am i getting this error?
If I remove U2B component in the schematic, i observed that I don't get the above mentioned error?
I am a complete newbie to multisim...
Now on LabVIEW 10.0 on Win7
(5,579 Views)
Accepted by topic author LV_Enthu
The way you created the op-amp section B is likely the problem. The model has 5 nodes while your section B symbol only has 3 pins.  Refer to the following tutorial, to learn how to create multi-section part with different symbols:
http://www.ni.com/tutorial/14438/en/
Tien P.
(5,559 Views)
