 LV_Enthu
			LV_Enthu
			05-03-2015 06:50 PM
Hello i am trying to simulate a simple active filter ckt using MAX9618. However, i keep getting error as Not enough nodes in my schematic I have attached the schematic for reference.
Can anyone please help me understand why am i getting this error?
If I remove U2B component in the schematic, i observed that I don't get the above mentioned error?
I am a complete newbie to multisim...
Solved! Go to Solution.
		05-05-2015
		08:24 AM
 - last edited on
		09-19-2025
		05:42 PM
 by
		 Content Cleaner
			Content Cleaner
The way you created the op-amp section B is likely the problem. The model has 5 nodes while your section B symbol only has 3 pins.  Refer to the following tutorial, to learn how to create multi-section part with different symbols:
http://www.ni.com/tutorial/14438/en/
