Multisim and Ultiboard
Error"Failed to resolve Convergence Issue"
I am working with the Multisim13 and I when I am trying to implement the design as attached shows a window saying ""Failed to resolve Convergence Issue" as shown in attachment.
I found similar threads here
http://forums.ni.com/t5/Circuit-Design-Suite-Multisim/how-to-solve-simulation-error/m-p/838043/highl...
http://forums.ni.com/t5/Circuit-Design-Suite-Multisim/Problem-with-simulation/td-p/2603281/highlight...
Btu were not upto the solution to this.
Thanks.
(7,584 Views)
Accepted by topic author GoviRe
According to the OPA381 data sheet it is designed to work with capacitive loads up to 100 pF, in inverting amplifier configurations, and as a transimpedance amplifier which typically is used with a (very small) current input and fairly large feedback resistors.  Your circuit operates with capacitive loads of ~ 5 uF (50000x the design load), unity gain, non-inverting configuration, and with a voltage input.  Depending on how the model for the OPA381 handles these out-of-normal range values, convergence errors may not be too surprising.
The coupling network between the stages has a low pass cut off of ~1.3 Hz. The first stage input network is more complicated but also limits bandwidth to very low frequencies.
What is this circuit supposed to do?
I simulated the coupling and feedback networks (assuming ideal unity gain amplifiers). This is the output with a 1 volt input.
Lynn
(7,569 Views)
Hello Lynn,
The circuit implemented is a Sallen-Key Butterworth lowpass filter with a cutoff frequency of 2.4Hz being driven by a low ressitance(OP-AMP) with a biasing and  having the phototranistor ouput to the OP-AMP.
If possible can you post the circuit you simulated having the output as shown in the figure in your post.
Thanks.
(7,551 Views)
The Sallen-Key lowpass filter has C3 connected at the R5-U2 junction, not as your image shows.
The attached file has the SPICE listing I used. Because I did only AC analysis, none of the DC sources are required. In the listing R2 is the parallel equivalent of your R2 || R3 = 50 kΩ. The op amps are modeled as linear voltage controlled voltage sources with gain of 1 (E1 and E2). R5 was omitted because no current would flow through it. In the corrected Sallen-Key circuit it will be necessary.  Resistors Rv1 and Re1 are probably not necessary but assure a DC path to ground from all nodes.  I do not have Multisim. These files are modeled with a SPICE 3f5 engine.
The file test 2 stage.txt is the listing for the circuit in your image and test 2 stage SK.txt is modified to represent the Sallen-Key circuit.
The plot below is my analysis of the Sallen-Key version.
Lynn
(7,519 Views)
