07-30-2007 08:42 PM
07-30-2007 09:57 PM
07-30-2007 10:10 PM
07-30-2007 10:18 PM
O.K. I tried the forward annote and it did turn force vectors back on. It is my opinion that this may being caused by the way Ultiboard is being updated from Multisim. When you forward annote it seems to me that you are overwriting the current project file with basically a new file. Based upon what I observed, Ultiboard is treating the forward annote basically as new project. even though everything looks the same on screen except for your changes.
These are just my observations. on this subject. Nestor or Max may have better information for you.
07-30-2007 10:26 PM - edited 07-30-2007 10:26 PM
Message Edited by kittmaster on 07-30-2007 10:26 PM
07-31-2007 07:59 AM
I kept trying the autorouter last night and I never could get it to reproduce this problem. I am going to continue investigating this and see if maybe there is a way to prevent the project view from resetting after changes are made to the project. I am hoping that maybe something in the main setting may need to be changed in order for this not to occur. If I find anything I will definite post my findings.
In the meantime, Nestor or Max may have some information that could help that we just don't know about yet.
07-31-2007 12:46 PM
No Joy. I have been through every menu I can find and I haven't found anything that I could change that would keep this from occuring. This may be something that needs fixed internally in software and not something we can alter through any settings. Nestor will have to look at this and let their R&D team take a crack at it.
I tried everything I know. Sorry I could be of more help.
Have a Nice Day.
07-31-2007 12:58 PM
08-01-2007 03:53 PM
Chris, Lacy,
Yes, this indeed should be a global setting. I checked in v10.0.1 and I can reproduce it when you annotate or import netlists, on these cases the project makes a reset, therefore bringing the design toolbox to its default state.
However after autoplacing, autorouting, I can't seem to rpeoduce the behaviour, the ratsnest or force vectors keep turn off.
I checked with R&D and yesterday they filed the report to check how to make it remember the setting after project resets like annotates or imports...
