Multisim and Ultiboard
Flash parallel converter
Hello everybody,
I´m currently trying to modify the 16 bit flash-converter you can find attached to this post so it works as a 64 bit - converter and for whatever reason I seem to be kind of blind since I´m not getting any further for several weeks now. It´s part of a spare-time-project and every once in a while I sit down after work waiting for an ingenious idea to pop up but so far...it doesn´t work. I already say "Thanks!" for any suggestions that bring me closer to my goal!
Felix
(3,628 Views)
Hi Felix,
Your files seem to be using a Hierarchial Block which is not posted. Can you post the Hierarchial block files as well.
Tayyab R,
National Instruments.
(3,605 Views)
Hi Tayyab R,
thanks for the hint. Of course yes - I forgot to post it. As you can see, four of the blocks (2bit flash converters are connected) so they can count up to 16.
My goal is now to take the 16bit_flashconverter file as one block and connect four of these logically so it becomes possible to count up to 64.
Any ideas on that?
Felix
(3,582 Views)
