Multisim and Ultiboard
RLC circuit transient analysis
i'm a computer engineering undergraduate student..i having a small problem on..RLC circuit transient analysis... i have problem on setting up step up voltage using multisim 11.. to produce a transient graph..need some help..
i attached the sample graph below..how u guys can help out..thanks
(5,457 Views)
Can you provide us with a circuit on which you are trying to run the transient analysis.
Tayyab R,
National Instruments.
(5,443 Views)
i tried with this circuit..it come out with the result..something similar to the graph tat i provide in the 1st post..but the value..not the same..i try to adjust a little bit and the graph gone other shape..plz advice..thanks
(5,438 Views)
You can get the same response curve by editing the voltage of the source. Take a look at the attached circuit.
Hope this helps.
Tayyab R,
(5,414 Views)
yea..if kinda solve half of my question..but..for the graph i attached.. when the voltage is ard 44V the responds time is about 30 micro second..but the circuit attached.. when the voltage is 44V is ard 300 micro second.. with 10 times longer..any chance to change the responds time?
(5,411 Views)
The response time is linked to the actual RLC values you are using. You will need to edit those to edit the response time.
Hope this helps.
Tayyab R,
(5,407 Views)
