Multisim and Ultiboard
Fourier and distortion analysis
I am analyzing harmonic distortion component in an output voltage of a circuit using both Fourier analysis and distortion analysis in Multisim 12 and I realize that the magnitude and phase given by both of the analyses are different. The magnitude and phase from distortion analysis is much smaller than the result from Fourier analysis and I suspect that it has been normalized. Is this true? If so, how has it been normalized?
Message 1 of 10
(8,271 Views)
Hi there,
I saw this post has been here for half a year, I was wondering if your problem has already been solved. If not, I will help you to figure it out.
Chen_T
Message 2 of 10
(7,626 Views)
Hi. I suspect that the distortion analysis in MULTISIM does not support ABM source. Is that true?
Message 3 of 10
(7,620 Views)
Hi there,
We do support the distortion analysis with the ABM source in Multisim 13.01.
Chen_T
Message 4 of 10
(7,616 Views)
To me, both of the provided samples (and their Help File descriptions) suggest that the "Distortion Analysis" is seriously flawed!
Message 5 of 10
(6,944 Views)
Then please provide details instead of some generic statement.
Message 6 of 10
(6,942 Views)
See second plot in "Distortion Analysis for Harmonic Distortion" and third plot in "Distortion Analysis for Intermodulation Distortion" Help Files.
Message 7 of 10
(6,939 Views)
You need to be more specific about what you consider flaws. Don't just point to plots.
Message 8 of 10
(6,933 Views)
Distortion levels appear to be on the order of 30dB - compare that to the Fourier Analysis results (which appear to be much more reasonable)
Message 9 of 10
(6,930 Views)
So, what's next?
Message 10 of 10
(6,867 Views)
