Multisim and Ultiboard
multisim
Hi all,
I  want to design Hysteresis current control technique  in Multisim.  For that design I require a component named relay which I didn’t find in Multisim.
In Labview  relay is there.  The  parameters of that  relay are as follows:
Switch on point:
Switch off point:
Output when on:
Output when off:
In multisim also some relay components are present but  I didn’t find any relay with above mentioned parameters.  So I request all  to suggest me a component in multisim  with above mentioned parameters.
Because of this problem I tried hysteresis control with COMPHYS block which is available in  Multisim, bit I didn’t get the exact result.  I am attaching the circuit which I have been trying. Please  verify the circuit and help me in getting the result.
Thanks in advance.
Message 1 of 1
(4,863 Views)
