Multisim and Ultiboard
Fourier series in Multisim
Is it possible to simulate random periodic signal which can be represented through Fourier series in Multisim? For example, Fourier series of sawtooth voltage with period T=2pi is
These terms on right side of equation will be AC voltage sources connected in series. For good approximation of sawtooth waveform I should use few hundreds terms of series. It would be impossible to connect all these sources manually 🙂 I know that Multisim has already sawtooth generator but I used it just as an example.
(5,909 Views)
Accepted by topic author etfpg
Take a look of the following LabVIEW Instruments for Multisim, they allow you to generate waveforms based on expressions:
Expression Signal Generator
Formula Signal Generator
Hope this helps.
Fernando D.
(5,879 Views)
Thanks!
(5,863 Views)
