Multisim and Ultiboard
Generic resistor footprint dissapeared.
Hello everyone,
I am using Multisim 10.
When I place a resistor, the generic footprint has dissapeared from the footprint options (1). When I place a virtual resistor with no footprint then select a footprint manually via right click > properties > edit footprint (2), I can select the "Generic - RES0.25" footprint(3) I was originally after. I have attached a picture to illustrate the options I have. Does anyone know how to get these generic footprints back into the initial footprint options (1)?
Thanks a lot
Dan
(6,318 Views)
resistor footprint options
(6,317 Views)
Accepted by topic author dannybeckett
In version 10 and later, RLC components are treated a little differently from regular components. To add a footprint to the list in the Select a Component browser, you need to add a new definition for a resistor.
  1. Click Tools > Database > Database Manager
  2. Select the RLC Components tab
  3. Click the Add button
  4. Set the following information
    1. Family name: RESISTOR
    2. Value: 1k (can be any value here)
    3. Footprint Manufacturer/Type: Generic/RES0.25 (or the footprint you want to add)
  5. Click OK, the Close
You should now see the footprint in the Select a Component browser.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(6,305 Views)
Perfect! Thanks a lot
(6,302 Views)
