Multisim and Ultiboard
moving database between computers
Hi!
I made a search here, but my time is not enough to make an extensive search.
I would like to transfer my Ultiboard User Database to another computer, cause I bought a new one. I copied the usr file (UsrComp_S.usr), I tried to merge it, it still shows me the User database blank. what I did wrong?
Thanx!
(3,341 Views)
I think you are copying the wrong file. The file name you mentioned is a template for users databases, not the actual the user database. If you have version 10 or later, the location of the user database depends on your operating system.
Windows 2000/XP
C:\Documents and Settings\<USER NAME>\Application Data\National Instruments\Circuit Design Suite\<VERSION>\database\UsrComp_S_USER NAME>.usr
Windows Vista/7
C:\Users\<USER NAME>\AppData\Roaming\National Instruments\Circuit Design Suite\<VERSION>\database\UsrComp_S_USER NAME>.usr
If you cannot find it there, you can find the path in Multisim
  1. Click Options > Global Preferences
  2. Select the Paths tab
  3. Find the User Database row
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,328 Views)
