Multisim and Ultiboard
Has anybody found a vco like LM566 model?
HI,
Has anybody found a vco like LM566 model? I need simulate the running of vco for my students.
thank you so much.
MCP
(10,447 Views)
We recommend to look for a specific model at the part manufacturer.
Sincerly
Bruno Cesar
(10,341 Views)
Sincerly
Bruno Cesar
(10,341 Views)
I'm assuming the building block VCO's are unsuitable for your purposes?
For examples, VOLTAGE_CONTROLLED_SINE_WAVE, VOLTAGE_CONTROLLED_SQUARE_WAVE,  or VOLTAGE_CONTROLLED_TRIANGLE_WAVE are building blocks.
It all depends on what you're trying to do.  For example, I was trying to simulate a PLL, but the PLL tool is inadequate.  Hence, I can use building blocks and simulate one that acts like the PLL I'm trying to simulate.
(10,317 Views)
I'm always interested in helping students (and their instructors).  On that note, I just passed along a phase-locked loop circuit to the forum, through a thread I began many months ago.
This url,
http://forums.ni.com/ni/board/message?board.id=370&message.id=50&query.id=581439#M50
should get you to the thread.
It isn't what I'd call a "designed" PLL, as I tweaked it into operation (the 1k was increased to 10k).  But I think it's still pretty cool to play with, and I thought your students and the others here might like it.  However, do note that I used a building block VCO. ...at least for the moment that is. 😉
(10,314 Views)
I have tries (attached file) frequency is changing but the problem is that its amplitudeis also is changing
dr_parjit@hotmail.com
(7,544 Views)
I have tried a oscillator controlled by input voltage (attached here), but along with its freq the amplitude is also changing dr_parjit@hotmail.com
(7,542 Views)
