Multisim and Ultiboard
Having problems with 4066
Hi. The problem is that the input signal is diferent to the output signal when it's suposed that should be the same. Here is the file
(3,889 Views)
Your connections are incorrect. I have posted the correct configuration below. I don't mean to sound like a butthole, but anytime you try to design a circuit it helps to consult the components datasheet  for proper hookup. This will save you a bunch of headaches in the future.
Have a nice day
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,876 Views)
