Multisim and Ultiboard
Internal Error 2738 - Can't install NI Circuit Design Suite
Hello
I've tried to install NI Circuit Design Suite V10.0.0 and V10.0.1 a couple of times now, but I get the same error all the time.
Restarting my computer doesn't help, and I'm shure my PC is good enough (2.8 GHz, 1.5 GB ram, Nvidea 6800GS/XT, 500+ GB space) for this program to run.
I have Windows XP PRO English with SP2 as my OS.
Both gave the same errors:
The NI Circuit Design Suit 10 Core installation has failed with the following error.
Internal Error 2738
Continue?
[Yes] [No]
The NI Circuit Design Suite Support and Upgrade Utillity installation had failed with the following error.
Internal Error 2738
Continue?
[Yes] [No]
exactly I've the same problem as on this topic: http://forums.ni.com/ni/board/message?board.id=6170&message.id=2982, but there was no solution for the problem (as far as I was capable to read).
I hope someone has a solution for this problem...
JB3
(5,297 Views)
Hi JB,
I searched Microsoft website for this error code and there are two suggestions I found:
  1. Re-register the vbscript.dll
    1. Start -> Programs -> Accessories -> Command Prompt
    2. Type CD %windir%\system32
    3. regsvr32 vbscript.dll
   2.  Try to install Multisim again and if it fails, visit Microsoft website and download Windows Script 5.7.
http://www.microsoft.com/downloads/details.aspx?FamilyID=47809025-d896-482e-a0d6-524e7e844d81&DisplayLang=en
Tien P.
(5,270 Views)
Hello Tien,
Thank you for your reaction. The first step in your reaction gave the result I needed: The program is now installed correctly, and I can use it.
JB3
(5,258 Views)
