Multisim and Ultiboard
Help for PCB Stack up and MicroVia Ultiboard 7
i need some help with my PCB. I will design a 10 Layer PCB with micro-vias and buried-vias. I asked my PCB manufaturer for a matching PCB stack-up and
for the design rules.
Now I need micro-vias from the top-layer to the inner 1 layer and from the inner 8 layer to the bottom-layer. That works fine, i can choose it in the board settings. But, I need also buried-vias from the inner 1 layer to the inner 8 layer, and there is my problem, because I can't choose it. Have you guys
any suggestions how i can solve this problem ???
Many thank's to all...
Manuel
(4,150 Views)
Hello Manuel,
from my point of view you talk about this issue, didn´t you?
Blind Vias in Ultiboard v9 and v10
http://forums.ni.com/ni/board/message?board.id=370&message.id=479&requireLogin=False
How to create a via from layer 1 to 3 on a 8 layer PCB?
http://forums.ni.com/ni/board/message?board.id=370&message.id=4758&requireLogin=False
Regards, Jan
Jan Kniewasser | Applications Engineer | Tel.: +49 89 7413130 | Fax: +49 89 7146035
(4,132 Views)
