07-14-2008 10:31 PM
07-15-2008 05:16 PM
You're right. It can be interpreted in different ways. Maybe he will come back on here and let us know which interprettation is the right one. That way we can be assured that we can actually come up with a proper solution. ]
By the way, mine is the correct one, Ryan (LOL):smileyvery-happy:
07-15-2008 09:22 PM
07-16-2008 02:41 AM
07-16-2008 08:52 AM
07-16-2008 05:56 PM
O.K. I stand corrected and Ryan (butthole
) was right. This is not going to be possible in Circuit Design Suite. I don't know of any Layout packages that are capable of this.
What I don't understand is the forward annote problem you describe. When you originally transfer your design to Ultiboard it saves it to a file. Any further forward annotes overwrites this same file with new information from the changes you made in Multisim. Unless you intentionally erase the project file, then it should be accessible by Multisim. Let me know something on this as it sounds strange.
One possiblity on the original inquiry is to create a library of layout circuits with schematics from Multisim. Put these into a Multisim project and then call them up when needed. Create a blank board as the main layout and then load the partial layout and then copy and paste into the main circuit. This is the only solution that I can come up with and like I said I do not know if it is something you would even want to do as it could be a pain in the booty on a large design.
07-16-2008 11:17 PM
