Multisim and Ultiboard
High Power Amplifier Custom Component Import Pin Arrangement
Hi all,
I am trying to simulate a pre-amp circuit in Multisim with PA107. I have the .LIB file but am not sure if I have imported it correctly using Multisim Custom Component Wizard.
From the .LIB file, the order of the pin arrangement is as follow:
* BEGIN MODEL PA107
* PINOUT ORDER -IN +IN OUT +Vaux +Vsp -Vsp -Vaux +Vs -Vs
* PINOUT ORDER 36 35 20 22 19 29 25 43 44
In Component Wizard, I numbered the pins by the above order as follow:
GND +IN OUT +Vaux +Vsp -Vsp -Vaux +Vs -Vs
1    2     3       4         5       6       7      8     9
However, in the component properties windows, the "Pin" tab shows a different configuration:
I must have imported this PA107 incorrectly becaue the pre-amp circuit is working as intended, can anyone please provide any solutions?
Attached is the .LIB file of PA107. Thanks!
(3,094 Views)
Can you provide your footprint name so I can give it a try? Thanks,
Derek Z.
(3,079 Views)
