Multisim and Ultiboard
How Do I solder the buttom only?? help me plz
routing question.GIF my ultiboard version is 10,0,144
(3,902 Views)
Tools>>Netlist Editor>>Misc - Routing layers
(3,876 Views)
Dear SupSup,,,
thanks for you attention and reply,,,,
in my circuit i have to use the two layers (upper and bottom),, for routing nets,,,,
but when those nets will connect to a special part it should be connected from the bottom becuse i cant solder it's pins from the top ,,,
but in the same time i can't make all nets to be routed in the bottom layer only ,,,,,
in the net list editor  they deal only with the nets and the pins will connected to it,,,
i think this problem could be solved by in place part edit and make the pads of pins of that part in the lower layer only ,,,,
so in auto routing mode it will use the binifit of 2 layers but when it come to any pin it will connect it from the bottom ,,,,,
this is just an idea ,,, but i didnot know how to achive it,,,
can you achive it ,,,
sorry for my bad english 😉
(3,871 Views)
Accepted by MYMZ
Al-Hamdu Lilaah
thanks Allah
i found it ,,,,
the solve in this way ,,,
come to the part and right click ,,  choose In Place Part Edit and select by the mouse all it's pads and R-click and choose Properties,,,
choose Auto Routing Tab and select the lower layer ,,,, and it's OK ,,,,, 😉
(3,869 Views)
