Multisim and Ultiboard
How do I make a rectangle spade connector hole?
Hi, I have Ultiboard 9 (a bit old) and I am trying to make a rectangle hole in a custom footprint.  I followed the instructions in this forum, and got a beautiful part, but when I export it or preview the printout, the hole is missing.  Would anyone in the know care to look at my file that I am attaching?  I am trying to make the inside hole .295" x .061".  S1 has some kind of hole showing when I print it, but it looks too long.  I would appreciate any help.
(5,251 Views)
Understandably, I haven't had any response to this post. Perhaps someone has a pre-made rectangle pad/hole that I could modify to my own dimensions???  It's going to have to work on Ultiboard 9 or earlier.
(5,217 Views)
I think the holes in your file are okay. They should show up in the print outs. Make sure that in the print menu, you have the check-box saying Leave Drill Holes Open checked.
Hope this helps.
Tayyab R,
National Instruments.
(5,191 Views)
Thanks for replying Tayyab.  You are right, I didn't have the "Leave drill holes open" checked and so it looked like they were all closed.  However, the holes that appeared after I set the check mark, show up round, not rectangle as they are supposed to be.  I've tried a bunch of things, but can't get a rectangle hole.  Any ideas?
(5,187 Views)
It seems like this was a bug in that version. I was not able to find a way around that. The gerber files should be okay though for making the actual board.
Sorry for the inconvenience.
Tayyab R,
(5,159 Views)
You are right Tayyab, the gerber files do show a rectangle hole, but not the printout. I had to fuss with it a bit, but finally got the gerber viewer (I used Viewmate just to be sure) to show the rectangle hole correctly.  Thanks for your help.
(5,154 Views)
