Multisim and Ultiboard
How do I save a component from a schematic in Multisim 11?
When you double-click on a component, you should get a pop up dialog and there is an option to save the component to the database.  However, depending on the version you are using and which component you selected, this option may not be available.
Tien P.
Message 11 of 15
(1,570 Views)
In the student edition of Multisim, you can not save components from a schematic directly into the User Database. In other version, you can save regular components from the schematic directly into your User/ Corporate Database by right-clicking and selecting Save component to database. You can not save configurable/animated components to the User or Corporate database.
Hope this helps.
Tayyab R,
National Instruments.
Message 12 of 15
(1,569 Views)
Thank you for the response. I have the Student Edition.
Message 13 of 15
(1,564 Views)
I also have the student adition and have the same problem I downloaded a thermister to a blank page and copied it to my schematic however i want to save it to my user database.
I dont know what kind of component this is but what do i have to do to make it saveable.
 Edit . I have version 12
Message 14 of 15
(1,536 Views)
What you can do is double-click the component and go to the Value tab. Click on Edit model and copy the spice model from here. You can then create a new component and paste this spice model when prompted for the model.
Here is a tutorial on component creation.
http://www.ni.com/white-paper/3173/en
Hope this helps.
Tayyab R,
Message 15 of 15
(1,507 Views)
