Multisim and Ultiboard
How do I save the output of the logic analyzer?
I can't find a way to save the output of the logic analyzer.  Even a set of graphical images would be fine.  Other than manually doing screen caps, is there any way to grab that output - in any form?
(3,987 Views)
Please take a look at the attached screen shots. You can open the Grapher after you run an analysis and you will see the output from the Logic Analyzer. Then you can save this or export this information.
Hope this helps.
Tayyab R,
National Instruments.
(3,972 Views)
Thank you so much.  That was exactly what I needed.
(3,969 Views)
