Multisim and Ultiboard
How do i tell Multisim 10 that a net may be on every layer in Ultiboard 10
How do i tell Multisim 10 that a net may be on every layer in Ultiboard 10 (multilayer board).
(3,599 Views)
This is not directly possible in Multisim 10 and earlier. The best you can do is blank it out (don't specify anything).
This has changed in version 11. Now you can specify routing layers in Multisim the same as you would in Ultiboard (including stack-up layers).
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,593 Views)
Accepted by Frankeman
(3,588 Views)
