Multisim and Ultiboard
How do you delete the paste mask layer from the pin of a part in the part editor?
I made a part in the editor that has a couple of rectangular pin pads that I don't want paste masked. How do I delete the paste mask layer from the pins of a part in the part editor? I'll take any work arounds you can think of as well. I am using version 10.1.372 Thanks much. T
(3,499 Views)
Accepted by topic author Todc.18
To disable the paste mask, right-click the pad and select Properties. Go to the the Pad tab. On the bottom right, you will see checkboxes for Solder Mask and Paste Mask. You can un-check to remove paste mask.
Hope this helps.
Tayyab R,
National Instruments.
(3,497 Views)
