02-17-2012 10:57 AM
I made a part in the editor that has a couple of rectangular pin pads that I don't want paste masked. How do I delete the paste mask layer from the pins of a part in the part editor? I'll take any work arounds you can think of as well. I am using version 10.1.372 Thanks much. T
Solved! Go to Solution.
02-17-2012 02:09 PM
To disable the paste mask, right-click the pad and select Properties. Go to the the Pad tab. On the bottom right, you will see checkboxes for Solder Mask and Paste Mask. You can un-check to remove paste mask.
Hope this helps.
