Multisim and Ultiboard
How does the n turns ratio works in Multisim 10?
hi friend
   i am trying to simulate one flyback converter in the multisim software 10.1 version. There i didnt find the option to change the turns ratio of the transformer. please guide me . How to set the primary and secondary turns ratio
thank  u
Message 11 of 20
(6,960 Views)
Try the TS_XFMR1 or TS_IDEAL component in the TRANSFORMER family of the Basic group in the Master Database.
Yi
Software Developer
National Instruments - Electronics Workbench Group
Message 12 of 20
(6,956 Views)
Thank you for your reply
    I am not finding options under Transformer library. I am having options under non-linear transformer. how to set the transformer turns ratio under non-linear transformer library
i am using multisim 10.1 version.
please provide some document regarding how to set turns ratio
i followed few steps:
non-linear transformer-----> Edit Model ------>
R0 2 5 66
    L0 5 6 146m
    A0 (6 1) (7 0) nlt_pq_4_12_lcpl_0
    A1 (7 😎 nlt_pq_4_12_mcore
    A2  (9 3) (8 0) nlt_pq_4_12_lcpl_1
    L1 9 10 1.64m
    R1 10 4 720m
.MODEL nlt_pq_4_12_lcpl_0 lcouple(num_turns=1.622K)
.MODEL nlt_pq_4_12_mcore core(
+   H_array=[0 13.89 51.58 222.22]
+   B_array=[0 1 1.5 1.7]
+   area=130u length=76.15m
+   input_domain=10m fraction=TRUE mode=1)
.MODEL nlt_pq_4_12_lcpl_1 lcouple(num_turns=178)
R0 2 5 66    L0 5 6 146m    A0 (6 1) (7 0) nlt_pq_4_12_lcpl_0    A1 (7 😎 nlt_pq_4_12_mcore    A2  (9 3) (8 0) nlt_pq_4_12_lcpl_1    L1 9 10 1.64m    R1 10 4 720m.MODEL nlt_pq_4_12_lcpl_0 lcouple(num_turns=1.622K).MODEL nlt_pq_4_12_mcore core(+   H_array=[0 13.89 51.58 222.22]+   B_array=[0 1 1.5 1.7]+   area=130u length=76.15m+   input_domain=10m fraction=TRUE mode=1).MODEL nlt_pq_4_12_lcpl_1 lcouple(num_turns=178)
Here which parameter i need to change to set turns ratio?
please do some need full
Thank u
Message 13 of 20
(6,950 Views)
Try the NLT_VIRTUAL component. You can modify the transformer properties by double clicking on it.
Yi
Software Developer
Message 14 of 20
(6,948 Views)
 There is no option called NLT_VIRTUAL,
i have only following options under Non- Linear transformers  library
NLT_PQ_4_10
NLT_PQ_4_16
NLT_PQ_4_20
NLT_PQ_4_24
NLT_PQ_4_28
NLT_PQ_4_36
NLT_PQ_4_48
NLT_PQ_4_56
NLT_PQ_4_120
If i want to keep primary/secondary turns ratio as 1.75, where to edit in the following parameter?
what is the meaning of num_turns=178?
if i change this value to 1.75 i am not getting my desired output.
what parameter i need to change here?
pls do some need full
Thank you
Message 15 of 20
(6,945 Views)
The NLT_VIRTUAL component is located under the BASIC_VIRTUAL family.
Yi
Software Developer
Message 16 of 20
(6,927 Views)
Thank you soo much
   i found that option
Thanks a lot Smiley Happy Smiley Happy
Message 17 of 20
(6,919 Views)
Hello friends
   How to choose two isolated secondary winding and one primary winding.
   I found the centre-tap trasformer, but i didnt find two secondary which is isolated from each other.
please help me out
Smiley Indifferent
Message 18 of 20
(6,910 Views)
For simulation purposes, try this:
1 - Place two transformers
2 - Connect their primary windings in series
3 - Use the secondary windings as 2 independent coils
Hope that helps.
Yi
Software Developer
Message 19 of 20
(6,900 Views)
Wowww......
superb idea
Thanks a lot friend  Smiley Happy Smiley Happy Smiley Happy
Message 20 of 20
(6,895 Views)
