Multisim and Ultiboard
How to change the line to line clearance of Ultiboard?
我正在用Ultiboard画一个PCB,但是好像是线间距设置得不太对,请问线间距设置在什么地方?芯片的引脚间距出现错误芯片的引脚间距出现错误
(3,182 Views)
Under the properties of the items, e.g. pad or track, you have a attribute that says clearance and its value is set per default to e.g. 10000. Just change this to suit your needs. You can even set it to 0 if you want.
(3,147 Views)
Thank you for your reply.
(3,134 Views)
