Multisim and Ultiboard
Operation of an Astable Multivibrator (using the 555 timer)
Hi all,
I just need to know if the operation of my 555 timer is correct. Basically, I have it in the astable configuration. I am given a 1uF capacitor and I need to generate a pulse with a tH of 1 second and tL of 0.5 second. Doing the relevant calculations, I end up getting 714285.71 Ohms for both R1 and R2. However, during the first pulse my tH is ~1.57 seconds (LED on)  and tL is 0.5 (LED off) seconds:
After the first pulse, tH is ~1 second and tL is ~0.5 seconds. I have not tried this practically as yet. Is this the normal operation of a 555 timer?
Thanks in advance.
Regards.
(4,157 Views)
Apparently, the textbook I am studying from (Digital Fundamentals by T.L Floyd) seems to be using the wrong formula.
For tH the textbook uses:
tH = 0.7*(R1 + R2)*C
The correct formula is suppose to be:
tH = 1.1*(R1+R2)*C
(4,135 Views)
