Multisim and Ultiboard
How to create a part with SMD pads on top and bottom layer
I'm trying to create a part that is a printed antenna. The board will contain an array of these so I am trying to create it as a part I can place. The active element of the antenna is on the top layer and the ground part is on the bottom layer. So I need an SMD pin on top for the active element and I need an SMD pin on the bottom to connect that part to ground. But I can't seem to be able to place an SMD pad on the bottom layer. How can I do this?
(5,009 Views)
Accepted by jg_geadinc
You can change the layer for the SMD pin in the footprint editor. Right click the pin you want to change, and select Orientation > Swap Layer. It is now on the bottom.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(4,997 Views)
Of course! you can change it from a right click but not by the properties tab (it's greyed out).
Thanks.
(4,988 Views)
New question, How do I associate a copper area on a part with a pin?
(4,983 Views)
Thanks for the additional information. I've entered this into our defect tracking system so that I can resolve this for a future relase. If you want to check the status, the ID is D114004.
Garret
(4,981 Views)
Never mind, I just created the part using custom pad shapes rather than copper areas.
(4,975 Views)
