Multisim and Ultiboard
How to subtract one signal from another, using an oscilloscope?
I have two chaotic oscillators, which I am trying to synchronize. There is an oscilloscope, whose channels are linked to each oscillator. I need to subtract B-oscillator's signal, from A-oscillator's signal, using the oscilloscope, so that I can find the how much is the error between them. A-B would work just fine, but there's only A+B. Is there any way to do this, without having to add extra circuit parts? If not, what should I add, to subtract one signal from another?
Edit: I am using the classic Multisim 13.0 oscilloscope.
(7,126 Views)
Accepted by GengisKhan
hello.
you can invert signal B -
the standard 2 ch scope has inversion for channel B - there are 4 small buttons on the bottom of chB instead of only 3 for chA.
best regards
Michael
(7,109 Views)
Thanks a lot!
(7,092 Views)
