Multisim and Ultiboard
I can´t find the LM317 anywhere in multisim....
Hi... well Im trying to build a circuit and I need the LM317 to create it, i can´t find it anywhere in the internet... could someone please help me out?, i have the multisim version 10....
I´ve seen some codes but I don´t know where to put them....
Any help would be appreciated...
Eugenio
Message 1 of 20
(69,611 Views)
Your search technique seems to be the problem.  Select Master database, sub group select all families, *LM317* should return 5 different parts......
Message Edited by kittmaster on 10-10-2008 03:39 PM
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
Message 2 of 20
(69,604 Views)
thanks for the quick answer!
I´ve tried again, "master database" "all groups" "all families" and the only results i get when i type LM are timers (like the 555), but not the LM317... I would appreciate your help....
Thanks!
Message 3 of 20
(69,592 Views)
Accepted by gugo8940
The problem may be that your verison does not have them. I have the Power Pro edition and they are in POWER>Voltage Regualtor. I trie a search for them and that wored great on mine. So this tell me that you may notm have them.
I am going to post one from my database for you. You may be able to save this to your database depending if your version supports that function. If not, then you can still use it by copying and pasting it into your circuit.
Here it is:
Kittmaster's Component Database
Have a Nice Day
Message 4 of 20
(69,578 Views)
thank you very much lacey
worked great this time
thanks!
Message 5 of 20
(69,568 Views)
I need it too,thank you!
Message 6 of 20
(68,154 Views)
Thank you!  I needed the LM 317 as well and I was able to use the file from your post.
Message 7 of 20
(64,494 Views)
Also try LM117 its the same part for military
Message 8 of 20
(64,480 Views)
HOLA NO ENCUENTRO EL COMPONETE,: LM317AH ESPERO QUE ME AYUDEN.  O COMO LO DESCARGO TENGO LA VERSION 13 MULTISIM
Eugenio
Message 9 of 20
(46,795 Views)
Mira la solución arriba, puedes descargarlo del link que pusieron
Message 10 of 20
(46,770 Views)
