Multisim and Ultiboard
I created new model 74HC123A, and it does not work properly. I don't know what's wrong.
I try to make 74HC123A model by myself using CD4538 model as a prototype.
I have failed. There is my effort in 123 CHASSIS.zip file. Please Help!
truly yours Aleks
(3,496 Views)
Hello 74HC123A
What process are you following?
Diego H
(3,458 Views)
It's simple, since both chips are the same functionality, I simply remapping the pins in the simbol pin name leaving the model node name intact.
truly yours Aleks
(3,450 Views)
otvinta,
I suggest you try this step by step guide.
Creating a Custom Component in NI Multisim
http://www.ni.com/tutorial/3173/en/
Diego H
(3,439 Views)
That's exactly what I did first time, and check it out once more now, and I didn't find any mistakes.
truly yours Aleks
(3,412 Views)
Accepted by otvinta
Thank you all, I've found the right solution.
truly yours Aleks
(3,308 Views)
