Actually it is working but your not using the equipment correctly.  You need to set the generator from 10Hz to 10Khz.  You need to set the initial and final values of the bode plot from say 4k initial to 20khz final and the input to 0db and final to 50db.  You also forgot to ground the output ground terminal of the bode plot.......try that.  The second order is pretty sharp appears to working.
