Multisim and Ultiboard
INA122 - Burr Brown
Does anyone know eher I can get hold of a IN122 Instrumentation amp for multisim student version 10.1 as it is not in the list.
INA122 - Burr-Brown
Any help would be greatly appreciated!
Regards
Dave
Message 1 of 11
(7,401 Views)
You can create your own INA122 component in Multisim using the Component Wizard, here is a tutorial:
Creating a Custom Component in NI Multisim
You'll need a SPICE model to create a simulatable component, I found one here. Go to the Simulation Models section and download the INA122 PSpice Model. This zip file contains 3 files, the *.mod file is the want that you need (open this file with a text editor).
Hope this helps Dave.
Fernando D.
Message 2 of 11
(7,392 Views)
Hi Fernando,
Thanks, this is great!
Regards
Dave
Message 3 of 11
(7,385 Views)
I have a need for a model of this amplifier too. I have downloaded the SPICE model and I attempted to make a part. Everything seems like it's ok but when I try to run it I get 0 as an output from the amplifier. I believe I set everything up right when I went throught the component wizard and I followed the steps. Any idea why it won't work? I'm not getting any errors either.
Message 4 of 11
(7,226 Views)
Attacht your component and circuit here, I'd like to do some troubleshooting. What's your Multisim version?
Fernando D.
Message 5 of 11
(7,216 Views)
How do I attach my INA122 component? Can I just attach the multisim file and it will be included? Or do I need to add something separately? I am using Multisim 11.
Message 6 of 11
(7,214 Views)
Just place your custom component on the workspace, save the Multisim file and attach it here.
Fernando D.
Message 7 of 11
(7,212 Views)
Ok, here's the file. I named it INA because I had other INA122 parts I had already attempted to make and hadn't deleted yet. The connections I have made are for a 205 gain amplifier. I used the datasheet for the hookup. Thank you
Message 8 of 11
(7,208 Views)
The component that you created didn't recognize the SPICE model, basically you had a layout-only component (green). I found out that the problem were the last 3 lines of the SPICE model:
.ENDS INA122
I just removed these lines.
I also edited the symbol and mapped the symbol pins to the model nodes. Attached you will find the new component, right-click and select Save Component to DB and save it to your User Database.
I didn't test the component.
Hope this helps.
Fernando D.
Message 9 of 11
(7,201 Views)
Thank you very much! I'll give it a try!
Message 10 of 11
(7,198 Views)
