Multisim and Ultiboard
INPUT IMPEDANCE
I have a op-amp feedback configuration.
What instrument or analysis can I use to find the input impedance of the op-amp.
Also, what instrument or analysis can I use to find the slew rate.
Thank you.
(4,883 Views)
slew rate on a oscope volts per second. Z can be measured by the input current and signal voltage using ohms law
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(4,878 Views)
okogidi,
To measure DC input impedence, just apply a DC input voltage, measure current though it and divide the two. To measure current, you can place series ammeter component or use static probe(last icon) in instrument panel
Slew rate is a large signal phenomenon so you need to push your op-amp out of linear mode using a large, fast rising input signal. Set your opamp to unity gain and apply a reasonably large input pulse voltage (2 or 3 volts will do), using clock or pulse source components and use oscilloscope to probe output voltage. The slope of the output is your slew rate.
Cheers,
Max
(4,865 Views)
Hi can someone tell me how to plot an input and output impedence graph against frequency for a common emitter amplifier.?
i mean what kind of analysis to i use?
Many thanks in advance!!!
(4,488 Views)
