Multisim and Ultiboard
IR2110 problem with new components. PLEASE HELP!!!!
Hi, what's wrong with these components? I was looking for IR2110 on multisim forum. I found this one IRF2110, but I think it's not working right. So I created a new one IR2110. I belive that it's not correct also. Can anyone check these components and tell me which one is the correct or what I must do to be right. I need it emergency!!!
Thanks in advance.
(4,329 Views)
Hi Mike_85_,
I don't believe that we have had any issue with the IR2110 before. What do you mean by it is not correct? Can you please provide more information on this.
Shalini B
National Instruments UK & Ireland
(4,287 Views)
Hello, I mean if those components works correct.... When I give to them pulse on the HI and LO pins the output on HO and LO are different for each component.
(4,279 Views)
