Multisim and Ultiboard
Import schematic changes to a board already laid-out
HI all,
I'm new to Ultiboard and Multisim and recently hired to do PCB contract work.  I have been able to make several schematic changes to an existing board and have verified the changes by reviewing those changes in the new netlist. How do I transport those changes into a current Ultiboard design? I'd like the changes to be a revision to save time by modifying/changing the existing design, not a completely new lay it out. It will require several parts to move and some component changes as well.
If it helps, I'm using Multisim 9 for the schematic and Ultiboard 9 for the physical board layout. The board is double-sided with a complicated shape, and there are glue pads and silkscreen layers as well.
By the way, the tutorials are pretty good, but I haven't seen this issue addressed.
-Lee
(3,149 Views)
Hi Lee,
Have a look at this article:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YG5UCAW&l=en-US
you may want to look at this as well.
http://zone.ni.com/devzone/cda/tut/p/id/5394
Tien P.
(3,138 Views)
